can't move driver's seat
Hi Tony,
Should be fuse No1 20A drivers side. If you checked it with a meter and it is ok then you may need a small child or a lengthened hex key.
To prove the drivers seat module, put it in the passenger side. If it doesn't work you can take the cover off. You may find the forward end tracks damaged, which is repairable.
