Can't move top manually
Did you disconnect the motor from its connector when you hot wired it ? If not you may have blown a fuse. If you put 12v across the pump motor and when disconnected and hear nothing the pump is shot.
First off you need to get out of this thread and start another.
If you opened the petcock and you were unable to open the latch manually and if you disconnected both hoses and still unable to open the latch manually I would say you either have a clogged line, latch piston problem or a latch linkage jamming. As for your applying power to the pump be careful the pump is bidirectional by means of a polarity change on the feed to it. But why are you doing that when you isolated the pump from the latch and you still have a latch problem. What am I missing?
I think I need additional information on what is taking place with the roof and what you have done.
the latch is in the closed position with the top resting on top of it. the last time it worked, the top went dow and then the latch came up. when i went to put the top back up the latch went down befor the top met the header. the top has been stuck in that position since then. i can not get it to move with the pump or manually
From what I think you are saying your hoses are crossed. Check your PM
aholbro1
08-05-2021 05:02 AM
