Can't program garage door opener
Received 2,263 Likes
Did you push the "learn button" on the opener (I use a broom handle) and then re-push the trained button in the car within 30 seconds?
Push the homelink button two more times and the door should close.
You can purchase a newer rolling code Homelink off Ebay for less than $25 and swap it in. I put pictures in the FAQ stickies on how I replaced mine.
I also have garage door installed and garage door repair technician has programmed the opener with the door.
I was going to echo this repeater bridge setup. To my knowledge, there are 3 generations of Homelink devices. The earliest XK8/R support Gen 1 openers only. The later XK8/R Homelink modules added support for Gen 2 (rolling codes?). Gen 3 is not supported at all by a factory part. The way to make a Gen 3 opener work is to procure a Homelink bridge, which basically accepts Gen 2 signals from the car, and then re-issues them as Gen 3 to the opener. It is a "black box" device you put on an electrical outlet. I believe there is a process to "pair up" that black box to the opener itself, then the car has to do its own pairing with the box.
Followed manual instructions to program. Held remote at light garage door opener repair Virginia Beach till blinked rapidly which should indicate programmed. The programmed button will not open the door!
HELP!!
HELP!!
Try this...it worked for both my cars. (Recalling from memory). Clear all buttons first before starting using the instruction manual.
1. Start a programming procedure as instructed in the manual. Hold button down on both homelink and handheld transmitter until you get the fast blink error. That's the car telling you it is a rolling code opener.
2. Move quickly to the garage and press the learn button
3. Press and hold homelink in car for a couple seconds, then release. Garage light will blink if successful. Repeat if it doesn't. After two times, if it doesn't take, start over. Mine captured it on the first try.
Closer the better to the garage, also.
I think the key is getting it to fast blink error before moving forward.
I'm unable to test this again to make sure I haven't missed a step because I'm out of town, but if you have trouble, I can follow up street I return...in a month.
