Car sometimes dies when starting cold or runs irregularly
![Exclamation](https://www.jaguarforums.com/forum/images/icons/icon4.gif)
A few times my 2000 Jaguar XK8 will run irregularly or simply die when starting from a cold state; rpms fluctuates before dropping to zero. The acs light might or might not flash.
Seems like this could be a fuel pump issue? There are no error codes (checked at jag dealer). The dealer thought it was the fuel pump.
Any cheap things to try before pulling out the tank? Also, will generic fuel pumps work or should I get a brand name one from ebay for $150 or so if it's defective?
That only shows a gauge but I don't see it being sold, will the one from Harbor Freight work perhaps? Fuel Pressure Tester & Fuel Injection Pump Tester
Ok, I pulled some codes off the car when it was giving an ABS TRAC amber error:
P0300
P1316
P1111
Searching around the forums, I seem to have the crappy tensioners: VIN SAJJA42C2YNA02688, but I need to double check this since the engine was replaced after 73k miles.
So, this could be a classical chain tensioner problem, question is, is it self fixable by a novice (me) and if not, how cheap can I get the repair? There is a kit for $300, then I guess 2 hours labor on top of that = $500 min?
Cheers!
P0300
P1316
P1111
Cheers!
rusty37
06-07-2016 04:43 PM
1964Daimler
09-02-2015 11:41 PM
