Car stalls when put in gear
stalling out when put in gear
97 XK8 car starts fine. Shifter allows gear to be selected but then lurches hard and engine kills. Drove car to work and had no problem. Parked in parking garage on slight incline. Came out of work and had above issue. Open to suggestions not sure if I can get tow truck into garage hope I can get help to get it moving again. Thanks
help. Car starts and gear shift allows gear to be selected but kills when put into reverse or drive options. Idles while In Park or neutral
don t know if it matters but 8 hrs before car drove fine. Took it to work and parked in car garage and know won’t go into gear. Not sure but car is also on slight incline in garage. It is an 97 XK8 convertible. Help me get it home thanks
I changed 2 things:
The fuel cap and the fuel filter.
One or the other was the culprit... Price was so cheap, it was worth changing both.
never happened again.
Perhaps the lock up solenoid on the torque converter is bad, and has direct drive when put into gear. IF IT IS SAFE, start the engine and without braking, put it in gear and accelerate slightly to see if the car moves. something like starting a manual shift car in gear without the clutch being engaged.
newguy12
03-11-2013 08:01 PM
Peter Duffy
11-27-2011 06:00 AM
jagxkrtoofast
09-13-2010 11:40 AM
