Car won't start - Error code P1316 (Engine misfire)
My 2001 XK8 has been standing in the garage for 3 months while I was in the UK. Last week my son took it out for a run and it was fine for about 45 mins...ran great. He stopped at a store and when he came out the car would not start.
He arranged for a flat bed tow and put the car back into my garage.
This morning I connected the ODB handset and got an error number P1316 also individual P301,2,3,4,5,6 readings. Plus a Yellow engine logo lit up and a Yellow Error " Engine Shut Down"
Reading the FAB's it may be the fuel pump fuse? does anyone know where this fuse is and what number is the fuse?
The engine turns over ok, just does not fire.
All the lights come up and it has a new battery.
If the fuel pump is faulty does it throw up an error number of the ODB handset?
I erased the error messages, the Yellow "Engine Shut Down" does not appear but the car still does not fire up....PLEASE HELP!!
djpxk8 (10-24-2013)
Other than releasing the fuel lines under the car, which is difficult to access, it is not a particularly difficult or expensive job. There is a how-to on Jagrepair.com and a video on YouTube. The video is for a 2003 however that has a different style of pump.
djpxk8 (10-24-2013)
See my post above that crossed yours... you may not need a gauge if the pump is dead.
djpxk8 (10-24-2013)
I haven't used the Welsh pump specifically, but my experience with them are that they are reputable and knowledgeable.
Do check the fuse first though and make sure all relays are fully seated in the trunk fuse box before taking the plunge on the pump.
djpxk8 (10-24-2013)
djpxk8 (10-24-2013)
I have checked fuse number 7 "20amp" fuse OK, if fact I checked all the fuses all OK.
"Relays", there are 5? light brown boxes and some black boxes in there, which are the relays? black or brown? Which ones do I interchange to check them??
I got my wife to switch on the ignition while I sat in the trunk, but could not here any fuel pump noise??
The Pump is not very loud. When the Ignition is switched from off to on, the pump is energized for 1 second to pressurize the Fuel Rail. If you're in a quiet place and have the trunk (boot) open, you can hear the Pump if it's working.
djpxk8 (10-24-2013)
If still no luck, it is almost certainly the fuel pump.
djpxk8 (10-24-2013)
BrentGardner
28
04-26-2024 03:08 AM
Isoruku
06-19-2020 12:54 PM
1964Daimler
09-02-2015 11:41 PM
