I have been using a bluetooth casette adapter. It is stuck in the radio - will not go down and will not come out. Any suggestions other than grabbing it with needlenose pliers and pulling on it?
Thanks.
Unless your OG cigarette lighter socket is already in use, I recommend replacing your cassette adapter with a plug-in Bluetooth-to-FM adapter. Many also come with USB charging ports (and some with volts display).
