Caster adjustment
Guest
Posts: n/a
Guest
Posts: n/a
RE: Caster adjustment
Damn it...looked for the sheet for a while...i remember that the tech said it was only slightly off but that xk8's didn't have caster adjustment...i was considering going somewhere to have them balance it out with toe...but i'd rather see if someone knew of a way to game it a bit...sorry for the lack of numbers, just know it was slight and only a slight vear to the rightwhen driving...
If u have directional tires, swap the front left to right and see if it pulls the other way.
Noramally if you change upper control arms the caster shouldnt have changed if the shims were put in as they came out.
Let us no what kind of tires you have. And to answer your question, you can't really "fudge" the numbers on caster.
gunlocators
09-30-2015 08:05 AM
