The cat is out !
The cat is out !
Started the first turn after almost 5 months of winter hibernation. Runs perfectly Over the winter I installed new Welsh poly upper shock mounts and new lower shock bushings; new hand brake shoes ( $16 from Rock Auto !! ) and new rear pads. While doing this I noticed the LHS handbrake cable was fraying a bit so I replaced it. Absolutely ZERO coolant loss since I replaced the octopus and header tank last yer so I decided not to do the valley hoses for now. I do LOVE this car
The following 2 users liked this post by Barry_Tucker:
DavidYau (05-04-2019),
Scottsgreenjag (05-06-2019)
Another prowling cat
98 X100
Just letting her cool down to avoid heat soak. Kitty is purring
Glad to hear that your X100 is out of hibernation, and all is well.
First good run today after a winter of fixing. Both tensioners, transgo mod. Filter changes, fluids. Front wheel bearings, upper shock mounts front and back. Cooling hoses, including octopus, valley. Brake discs, pads. Rear shockers. Sway bar links.
But flawless. Better handling than my previous 94 XJS. Great power, stopping, excellent handling.
My expectations have been exceeded. Thanks Gus, Reverend Sam and countless others.
Time to get some miles in, heads turns, and your grin back.
DavidYau (05-05-2019)
wash
clay bar- Maguiars and Mothers
Maguiars 105 cutting compound
maguiars 205 polish
2 coats NXT tech wax Maguiars
i used a DA for cutting and polishing
I am just super thrilled with the Sapphire Blue Mettalic color, really shines through now.
ltd
@Jon89 If you have the hand brake shoes off the car the cable is not hard to replace. Mine was getting corroded/ frayed at the hub where the cable enters. A previous repair ( not mine ) had not properly replaced the plastic clip which holds the cable to the back of the hub and moisture had got in. The worst bit is getting the brake shoes on an off. the rest is easy.
Lizard Kitteh
07-28-2012 06:38 PM
alabamabill
11-27-2008 11:57 AM
