The CAT sounds angry - pics and video
I must say, however, at prolonged freeway speed, it does get a bit too loud. It would be great to install an electronic valve controlled exhaust - with a flip of a switch you can make it quite or loud.
This is not my daily driver. Driving the car every day with my exhaust would be a bit overwhelming. I am enjoying the sound and the attention for now.
I want to do something subtle, but I keep reading about the compromises made to the interior sounds. Phrases like rattle, drone, and now overwhelming keep popping up in these threads.
A little more of a GT sound would be nice, but not at the expense of interior comfort and the ability to enjoy a conversation at speed. I get enough grief from SWMBO already when the top goes down.
I read your posts as well and saw your video too. I like your sound a lot. This is why I wanted Borla for my set up, but was talked out of it by the mechanic. Actually, I was looking for Borla rear mufflers, but couldn't find the right setup. I'm curious how your car would sound with Borla in center, followed by straight pipes - without Mina boxes.
In a way I felt bad removing the OEM mufflers as they look almost new. I'm keeping them just in case.
I'll try to record a video clip with higher revs within the next few days. I must say, however, at prolonged freeway speed, it does get a bit too loud. It would be great to install an electronic valve controlled exhaust - with a flip of a switch you can make it quite or loud.
The following 2 users liked this post by xenophobe:
Jag#4 (10-13-2013),
User 070620 (03-07-2014)
It would probably be way too loud without the mina rears.
This is with the top down... and I really need to redo these vids, since doing them, the fill has sooted and is louder now.
VID_20120528_171915.mp4 - YouTube
With my setup, noise at freeway speed isn't bad at all. It's nice and quiet unless I give it moderate throttle. If I drive like an old lady, the cat is tame. lol
Hard to do precisely as start is difficult to judge, but reckon that was around 5.4 secs 0-60. Great sound..!
I took it to 90 mph
Some of you asked, so I did it - I made a short video clip of me pulling away from my house and then jumping on to the freeway for one exit. Sorry about the video/audio quality, but it's hard to accelerate to 90+ mph and hold a camera in hand . I had the camera focused on the speedometer. Upon reviewing the video, I must say that the audio is extremely deceiving. You can hardly hear the actual exhaust - more road noise and the wind. In reality, however, the exhaust note is GRAND. I can hear it while behind the wheel and it is loud. It's possible that my HD camera thinks that the exhaust noise is background noise and cancels a lot of it out. Anyway, I will try to take a video from outside - me driving away. I think that it would be a better indicator of how loud it really is.
pitifulpluto (10-13-2013)
Jaguar XKR at 90 MPH Sports Exhaust - YouTube
No other way to say it than HOLYCRAP!!! If that is so much better in person as you say then I think you have found perfection!
I am seriously giving this some thought.
Where you able to find a set of midpipes that are pre-bent?
That is the only thing that would stop me from going through with this.
Thank you so much for making this thread, I myself always thought the exhaust was bleak on these cars but most aftermarket exhaust cost a fortune.
DevSpider (10-13-2013)
#28
Pipes are custom made
#30
Borla 2-in 2-out Center muffler
Same here - I also inquired and was told that Borla does not make the rear boxes. I am asking about the CENTER muffler that Xenophobe is using. Chances are he used a Universal 2-in 2-out Borla muffler. If that is the case I want to know the model number of that unit.
#32
#33
Krajcok, you're right about the car having a mind of it's own. When the engine is below it's regular operating temperature, the car refuses to kick butt. However, at about 70mph, once I "put my foot down", it got on its way quite nicely. Next time, before filming, I will make sure that the engine is warm enough.
As far as I can tell, there's just a bit of unwanted resonance at about 1,700 RPM, but ONLY when the engine is cold. It goes away after a few minutes of driving.
I already ordered the Magnaflow X-Pipe and will be installing it at some point next week.
Btw, you're ride sounds good!
#34
X-Pipe
Magnaflow X Pipes - Best Price on Magnaflow Tru-X Pipes for Exhaust Systems - 38+ Reviews
As far as the install, figure about 45-60 minutes for a professional install.
#35
Pro XS Dual In / Dual Out 2.25". Not sure if mine was notched, but I don't think so. It has a built in x-pipe, at least it was advertised like that in 2011. In 2012, there's no mention of the internal x-pipe or diagram, but this is a page from the 2013 Catalog showing the internal structure. I don't drive my car anymore, my exhaust note tells me how to drive. I think the Borla is playing as much of a role as my NP cats. The difference between having this or the OEM center is like night and day without exaggeration.
DevSpider (10-16-2013),
#36
Xenophobe, your Borla looks like its a muffler and an X-Pipe all in one. At this point if I was to install the same model unit into my car, it (IMO) would suppress the exhaust note way too much. But in your setup it works really well. As I mentioned in an earlier thread, I liked your car's exhaust note the most from watching hundreds of clips. It's a perfect combination between being aggressive enough to enjoy and passive enough not to wake up the neighbors in the wee hours.
#38
Nice!! Nice!!
Im pleased with your results, because Im doing a gear change , exhaust, and cold air intake on my kitty soon.
I do like the silent sneaky approach lol and just past by some one lol silently , but that sounds nice, one more reason for me to drive fast lol/
Only one thing, stock exhaust is stainless and last a long time, muffler shops use aluminum that does not.
I highly rec a high temp coating or paint to eliminate rust, or pay the extra for stainless steel piping instead of needing it fixed every few years.
#39
my cat at full throttle. Sorry for poor video quality.
jaguar xkr 4.0 0-200 kph acceleration - youtube
