CD changer
Received 10,880 Likes
Welcome to the forum Doug Gordon,
I've moved your question from General Tech Help to XK8/XKR forum. Members here with the same model will be able to help.
Thanks Mike, tried that many times and just didn't work .but on a good note ; I was able to get her back singing again. Just by persistent playing with it. I think it has something to do with the rejecting button,and poking around the inside of the player.not to mention slamming the magazine back in pretty hard. But she started working again.
Had same problem try this link
https://blogs.oracle.com/miko/entry/cd_changer_repair
The screw on mine eventually loosened up again so see if you can remove it and put some loctite on the threads to keep it tight (not sure if you can or not) - DON'T get overzealous and torque down on the screw and destroy the plastic at the top of the gear like I did
Received 4,285 Likes
The following 2 users liked this post by sklimii:
djpxk8 (10-10-2017),
Orthodixie (10-02-2017)
