CD not loading
Guest
Posts: n/a
CD not loading
I have a 01 XK8 with the 6 disc changer in the trunk. When I crank up the car the radio says CD Load 1..and continues through CD load 6. Then it simply says CD No Disc.
Does that mean my cartrige is bad or the entire CD changer? I tried switching out different CD's but it's not reading the discs for some reason.
I don't have any error codes to speak of. Any ideas?
marc
marc
Received 3,905 Likes
Marco, odds are the drive motor for the spinning of CDs has failed on you. What you are experiencing is the CD player is not being able to read any information off of a disk. Therefore, because it is seeing no data, it is assuming that there is no disk there. Now, it is possible that the laser portion has failed to, but normally you will find that the player will be really sensitive to bumps and whatnot. I wish the outcome would be better, but it is looking like you need a new CD changer.
cd changer reads NO CD
You wont believe this. I found this guys repair on the internet, and gave it a try. IT worked. Ive read up on all the other posts, and most said to replace the changer or buy one on Ebay used. Once again, I also got the loading CD and then NO CD displayed on the radio. It just loaded all 6 cd's and stopped without playing. Here is the post that I found and it was simple to take out and repair. I hope this works for you and I still can't believe it WORKS !! AL in New Jersey
Bye the way, I own a 2000 Vanden Plas
http://www.howtomendit.com/answers.php?id=57464
Same problem on my 2000 xj8-This simple solution worked for me....try at your own risk.
Gently pull back carpeting from cd changer. remove 4 small philip head screws to remove changer. Disconnect pin connector and remove unit from trunk. remove the 6 small philip head screws from cd player casing. Gently seperate the rear of the casing (gently pry away tabs near main wire). Open the unit like a clamshell at the back of the changer. ( I opened the unit all the way up )Using a flashlight illuminate the internals. Spray a SMALL amount of lubricant (I used white lithium grease with long skinny straw attachment) onto the exposed gears and levers inside the unit. Temporarily plug unit into the wire harness and test before re-install. Repeat lubricant proceedure if "no love" and try again. My unit took two tries but then started reading and running properly ever since-I hope this works for you as this seems a common problem on this car. On a side note sold a Mercedes S-430 after spending $7000 on "maintenence" on a car with 80k miles the 2000 Jaguar XJ8 has been a much better car so far!
Cap't Morgan
November 2007
Cap't Morgan
November 2007
Guest
Posts: n/a
Try this link for changer issues
Try this link to NO Disc message from CDchanger. CD Disc Changer - "No Disc"
This worked for my similar issue.
If you follow all the suggestions on this post and this does not do it then you might have to get dealer service.
__________________
__________________
Disc changer
Well, after trying to lube up the motors with white lithium grease several times and every other trick in the book, I ended up purchasing a new disc changer from e-bay. I bought one that came from the same exact model as mine (2000 Vanden Plas) for $100, and now I have a disc changer that works. So, I suppose it wasn't an electrical problem, but a malfunction inside the changer itself. Seems typical. Also sad but true, it's too bad this model refuses to play mp3 c.d.'s.
