Center console 12v lighter replace
Hi All.... Can anyone let me know the part number for the 12v lighter in the center console of a 2005 XK8..... The one in my Jag has needed replacement forever and I am not able to locate the part number or somewhere to order it. A web place called Terrys Jaguar Parts used to have it.... but marked discontinued. No part number associated.
I would appreciate the help.
Thanks, Ron
Thanks, Ron
Received 4,339 Likes
If it just doesn't work, it may be that the connectors on the bottom are loose. They must be pulled off if the console is removed for some repair, and they are difficult to re-install. I extended the wires on mine just to make it easier next time. Check the fuse too ( I know you probably did this).
I just replaced mine with a smart usb charger and voltmeter, and then fitted 12v accessory sockets to the glovebox and trunk accessory connectors for traditional 12v sockets. Having a voltmeter is really nice in these cars.
I have my lighter socket available for free if you want it, I'm in San Bruno on the peninsula, just drive down and get it. Or replace with a USB like me
daboss085
09-11-2013 03:24 PM
