center dash vent removal
Guest
Posts: n/a
RE: center dash vent removal
hoosier, I remember reading recently around here, that you can reattach those vents again w/o removing them. If it is the same type of vent as the prior post (cant find it right now), you can make a little hook type tool, and pull the vertical bar back into the vent clips. Give that a try before dismantling your baby.
Guest
Posts: n/a
The plastic runners that hold the fins in place have become dislodged. ibjags mentioned that once the wood panel is removed that the center vent assembly is easily removed. How is the wood panel held in place and how do I remove it? Are they "push clips" similar to what holds the door panels on? Don't want to damage the wood panel. Thanks.
Guest
Posts: n/a
I've been out of town on business and haven't had time to attempt removing the wood panel. Hopefully this weekend I should be able to. My Jag has a few items that need attention and hopefully this site might have a few suggestions on how to fix them.
Thanks again
Thanks again
Felipe Pr (04-04-2012)
The plastic connecting rod was missing on both my horizontal vents so I needed to find another fix.
I used high strength fishing line and cut quarter inch sections of thin tubing to connect the horizontal slats. Think it like threading a large 'bead' [the tubing] in between each of the slats where the OEM plastic piece would clip on .
The thread was looped around the bottom slat through a hole at the end of the slat. This is where the OEM plastic clip fastens. Then thread a quarter inch piece of tubing threaded into the fishing line and thread through the next slat, etc. The top slat was tied off very tightly [using a special surgical knot that only me and my heart surgeon know about].
The tube can be cut on the diagonal or straight across offering the option of having the slats angle up, down or neutral when open. They cannot be fully closed, but there is another vent flap for that.
This procedure could be performed with the vent unit in the car, but it is not that difficult to remove which makes the job much easier.
Considering they were just flopping around and closing off air flow, this fix was pretty good. Even better when I found out the replacement vent cost $170.
Thx Matt. If the tubing was thinner, say less than 1/8th inch OD, then the slats would actually be completely functional again on the up and down adjustment.
I used 1/4th inch tubing. As it is, they move up and down through a 30 degree arc; enough adjustment for my needs.
Somebody who like to string beads would have a field day with this fix!
OregonJag (06-16-2012)
Redline (10-08-2016)
