Center Muffler to X-pipe
Got an itch and wanted to scratch it. Got the center muffler swapped out for an x pipe (kept the muffler, though, just in case). The before and after axle boxes are factory.
I wasn’t looking to get that much louder. And it didn’t. Massachusetts bans any exhaust mod designed to make your car louder, so I didn’t want to attract attention. I just wanted the car to sound a little more like it feels when I mash the throttle. It will definitely sound still too tame for many, but this is probably the sweet spot for my preferences and environment. No drone, also.
Of course, actual sound clips are most helpful for the curious. Let’s see if this works. First rev is to about 2k, second is to 3k.
It looks like they used a premade x-pipe identical to one you might find from magnaflow (link here) and then welded on some new pipe to make up for the length lost by the center muffler. Took them less than an hour. Out in florida you will probably be able to get this done more cheaply than I did.
I will try to get an underside pic later, but it's pretty much identical to this: https://www.jaguarforums.com/forum/x.../#&gid=1&pid=2
Also, to revise my earlier statement: the x-pipe is stamped. Looks like the one in the XJ8 above and also like this one from summit racing
x-pipe: quietest replacement for center muffler.
h-pipe: louder than x-pipe.
straight through: similar to h-pipe, but more rappy, less balanced
Some people also reported back feeling less power with an h-pipe vs. an x-pipe. But I'm supremely doubtful that any of these on their own make any practical difference in power.
Benson7
03-22-2019 10:08 AM
2010 Kyanite XFR
05-16-2017 10:02 AM
havnfun
04-07-2012 11:06 AM
