Central locking
Guest
Posts: n/a
Central locking
1. Remote switches off alarm/opens boot and operate headlights but does not open the car
2. Key works ok but just the driver door unlocks - not the passenger door
3. Doors do not lock on drive away anymore.
4. Windows godown the small amount to open the door but does not go back up when you close the door.
5. everytime you pull the door handle the window goes down a small amount - e.g if you pull the door handle 5 times the window goes down 5 times
I solved the windows problem,but the central locking is still remaining.
I've checked the battery but the battery is perfect in condition.
Plz help me out
Plz help me out
RE: Central locking
Just thinking out loud;
The battery is the obvious first thing to check
Since both doors appear to be affected shouldn't be the door modules
Security module?
Still think the battery is the best bet. 12.5v without load? Turn lights on without engine running and check voltage. Should be at least 12.0v
Let us know.
tp
Security module?
Let us know.
tp
FS[NorthWest]: 2004 X-type 3.0 24,500miles! $8500
millertic
09-30-2015 08:11 PM
