Central Locking U/S and sets alarm off
![Cool](https://www.jaguarforums.com/forum/images/icons/icon6.gif)
Hi, I have an 02 XK8 convertible .When I try to lock the car using the key fob I can hear both doors lock and unlock twice and then the car alarm goes nuts.I have tried the soft reset by disconnecting the battery for 5 minutes but still no luck.I believe the battery is in good condition because it is connected to a trickle charger. Any help would be appreciated .
If I have a door open and I try to set the alarm on my 2000, the system beeps 1 time and it's a different tone than when the system sets the alarm. Once I shut the door or trunk/bonnet or hood, the alarm sets, locks the doors and beeps to let me know the alarm is set.
H20boy, the answer to your question is no.I get out of the car , try to lock the doors using the lock button on the key.I can hear both doors lock and unlock twice , then the siren starts. So I have to hit the unlock button to turn the siren off. I tried today to lock the car using the key in the door lock and the doors locked no problem at all. Atleast I know now that I can go to the shops and lock the car the old fashioned way . Thanks for your suggestions guys.
Get out the car.....lock using the lock button on the keyfob....can hear the doors lock and unlock several times then the alarm(horn) sounds....to stop i press the unlock button on the keyfob...this stops the alarm sounding, leaving the doors locked and after several moments the alarm indicator red light in the center consol starts flashing and i can walk away.!!!
Jag Convertable i just wondered if you ever solved the problem?
I know i get round it but it is annoying as the horn sounds....it seems something is not right. Any suggestions from you guys would be appreciated
I would first try the 'mechanical' investigation, but taking off the door panel and seeing if the locking/unlocking mechanism is easy to engage using the handle. Lubricate the working parts of the latch, perphaps its binding just enough to prevent the latch from automatically locking, keeping the circuit open, thereby setting off the alarm after a few moments. That is where I would start.
Well at the moment seems to be behaving itself
..... After what seemed like weeks of continuous rain here in the UK, the weather has finally improved ...... thankfully allowing both sodden car and owner to dry out somewhat............. taken the chance to do some real decent runs out, using the car and cranking up the milage .........surprisingly the locking system now seems to have sorted itself out with no imput from myself and is currently behaving as it should!!!!!!!........Coicidence?... maybe....but who cares, i'm just thoroughly enjoying the car
![Icon Doh](https://www.jaguarforums.com/forum/images/smilies/icon_doh.gif)
![Big Grin](https://www.jaguarforums.com/forum/images/smilies/biggrin.gif)
If you try to lock an XK8 with the remote, while a door is open, I believe the symptoms you describe can be duplicated.
**Correction: A functioning Door Ajar switch will signal the door is open and cause the security system to beep at you, and NOT lock the car. Please forget I shot my mouth off too soon.
![Icon Shrug](https://www.jaguarforums.com/forum/images/smilies/icon_shrug.gif)
Cheers,
aholbro1
08-05-2021 05:02 AM
FS[Western US]: XJS Lock Set with Keys- Doors, trunk, glove, gas, and ignition
XJsc-guy
11-23-2015 01:56 PM
