change battery
No big deal changing the battery.
Take the ground cable off first. Inspect the woven ground cable for corrosion as this has been a source of difficult to find electrical issues.
Take the positive cable off.
Disconnect the vent hose. Make sure that the replacement battery has a vent system and connect it back up.
Careful! That is a big, heavy battery and you have to lean over more than you should to pick it up.
Removing the battery will wipe out all your radio presets and the ECM will have to relearn all the fuel trim information. No big deal. Just drive it.
I have never heard of an US sold car having the radio security codes enabled but most of the rest of the world needs to ensure that they have that code available or the radio won't work.
Even in the UK where it was the standard fitting, a lost code card is not an issue. Jaguar Dealers can lookup the code for every vehicle from the VIN using the online Direct Dealer Warranty System. Jaguar CRC have also done this for members.
One thing that hasn't been mentioned. Following a battery disconnect the window travels limits will need resetting.
Possibly. The U.S. cars are not supposed to need a radio code when the battery is changed, but my 2005 S-Type did indeed require the code when I replaced the battery. My wife's 2006 XK8 has required two new batteries since we purchased it in February 2012, and in neither case did it require the code. Go figure....
Daim
10-09-2016 12:09 PM
