Changed dash lights Won' start !!
Old 11-09-2019 | 02:38 PM
G.Easter's Avatar
Default Changed dash lights Won' start !!
Well, a little more complicated than that, after disconnecting the battery, I removed the instrument cluster and replaced the 8 dash lights with new Sylvania bulbs. After reassembly I reconnected the battery. Now no response of any kind from the instrument cluster, and the engine will not turn over. Marker lights work but no headlights or tail lights. I checked the fuses for the instrument cluster (left door) but all are OK.
I am almost a hundred miles from the Jag dealer so I would really like to resolve this without having it transported. Any help is appreciated.
Old 11-09-2019 | 03:25 PM
avern1's Avatar
Assuming everything was fine before you changed the bulbs, the problem you are encountering would indicate the the main connectors to the instrument pack are not seated. Go back and recheck them.
MikeAlford (11-09-2019)
Old 11-09-2019 | 03:55 PM
It's the BLACK locking lever that seats the connectors positively.
Align the harness connectors and fully rotate the locking levers to ensure contact.
Old 11-09-2019 | 04:46 PM
G.Easter's Avatar
Have checked those connectors carefully, the locking levers are secured behind the plastic tab. I am pretty sure they are installed correctly.
thanks
Old 11-09-2019 | 05:15 PM
MikeAlford's Avatar
I had this problem. I found the yellow connector can appear connected when it's not. So disconnect the battery, take it off, put it back on and throw the locking tab across. On mine I assumed the locking tab would draw the pins together, but I found that was not the case. You need to push the connector on firmly before the locking lever.
Old 11-09-2019 | 05:29 PM
G.Easter's Avatar
Time to eat a little crow and say thanks again. Should have had a flashlight to begin with, black on black is tough for an old guy to see. It was the connector after all and all is well now (except for the check engine light which is new).
The following 8 users liked this post by G.Easter:
avern1 (11-09-2019), cjd777 (11-10-2019), DavidYau (11-09-2019), JimmyL (11-11-2019), Johnken (11-10-2019), michaelh (11-10-2019), Norri (11-10-2019), RJ237 (11-09-2019) and 3 others liked this post. (Show less...)
Lotahp1
12-02-2016 01:10 PM
dsd
10-18-2016 09:56 AM
Al Whitelock
11-09-2015 08:15 PM
jesusgonr14
02-28-2014 11:08 AM
wradford
10-13-2010 11:01 AM
Quick Reply: Changed dash lights Won' start !!
