Changed thermostat, now car will not start?
I decided to do some preventative maintenance on my 04 XKR and flushed the coolant, changed the thermostat and temp sensor. After putting the new thermostat in, the car would crank but not start. I am getting good fuel pressure at the rail and also did the battery connect/disconnect trick just in case, I also dropped a few ounces of gas into the throttle body. Still no joy, the car cranks strongly but does not fire. No lights or codes. Any ideas?
Pete
04 XKR Portfolio
Pete
04 XKR Portfolio
This is a long shot, but it may be a case of bore wash. There has not been any mention in the newer models that I can recall, but the extra fuel you introduced indicates that it may be a problem now if not before.
Try several bursts of the starter with the gas pedal to the floor to shut off the fuel, then try starting with little or no throttle. Removing the plugs and adding oil to the cylinders is a last resort. Do a search for bore wash.
But first check that the temp sensor and other connections have not been disturbed.
Still trying!
Some very good suggestions. I did inspect the harness area around the temp sensor but didn't check continuity. Tomorrow I will try putting the old sensor back in (though I can't see how a temp sensor could ground the ignition but stranger things have happened). I'll keep all of you up dated. Ironically, the temp sensor is the simplist sensor on the engine to change and the thermostat was a snap also, I should have known the kitty wasn't going to let me get away that easy!
Thanks for all the help!
craig_jeske
17
04-17-2016 07:06 AM
