Changing door speakers
There are two screws in the bottom of the grill and the will come out. Might be a little fiddly to get off but once removed should give you access to replace the speakers.
It has been a while but if I recall the best way is to rotate the forward part down and then unhook the rear tab. Reverse to reinstall.
max224 (07-26-2014)
