changing transmission fluid (XKR)
Received 1,701 Likes
on an '02 XKR,
to just change the fluid, is disconnecting the lines into the transmission cooler the easiest way to proceed ? Direct one line into the used fluid receptacle receptacle and on the other line, have a hose going into the clean new fluid container with the other end connected to the intake transmission line ? Bad idea ?
am wanting to put off doing a complete transmission service at this time.
is there a consensus on best synthetic ATF ?
Z.
Z.
on an '02 XKR,
Z.
Z.
Can't speak for the fluid flush. I just did a simple drain and refill 2 times, and the fluid in mine looks fine.
nasa25
09-07-2014 08:09 AM
mattrains
06-26-2013 05:15 PM
wordman
02-05-2013 07:23 AM
fasterthebetter
07-14-2012 11:34 PM
