Changing wheel size
You can visit tirerack.com and check the revs/mile to compare tires.
Devices that you refer to are available for some cars, Don't know if any are available for the XK.
The 20" Wheel option in the XK would seem to require a re-calibrated Speedometer system, maybe a software change.
zmann96 (06-03-2011)
As long as you keep the rolling radius within 3% you will be fine, the only time I have every heard of any probs is when somebody tried to fit 24's (bad move)
But click HERE, type in your original size then you can play with various tyre sizes and see what you get.
You will compromise the ride to a certain degree but that is the price you pay for bigger rims.
We have similarly bad roads in Wisconsin and I find a stiff ride with my 18" wheels (45 ratio tires) let alone a lower profile tire.
The tires provided with the 17" wheels have a 50 ratio.
Other things being equal, Lower profile tires will always provide a stiffer ride.
Thanks guys for all your input and comments. I decided to go with the 18" wheels. I made a mistake on one of my posts I had 245-50-17 not 245-45-17. I'm going with 245-45-18's. My speedo and odometer shouldn't be effected too much, I think there is only about .2 " in diameter difference. So I think my speed will show a wee bit more than what it should be and my odometer will show less than what I've traveled?? I think.
255/45/18 9" wide Rear
245/45/18 8" wide Front
You may want to consider using these sizes.
The Odometer reading changes should be negligible.
