Charge or Replace 2006XKRs battery
I needed some engine work but took my time checking out different shops ( no Jag dealership in my town). went to start it upand take it in.... no power. Its a 2006 XKR. How do you get in the trunk???? I have looked everywhere and the previous posts on other threds offer no help.... so sad watching it look at me...
You can also connect jumper cables to have one car CHARGE the other, but remove the jumper cables before starting.
The wiring at that point cannot handle the starting current and might cause damage if starting is attempted.
You can connect Jumper Cables or a Battery Charger to the the indicated points to:
1) Charge the Battery.
Or:
2) Open the door and press the Trunk Open Button to access the Battery for charging or to Jump Start the Engine.
There is 250 Amp Fuse between the under-hood points shown and the Battery/Starter and this Fuse might Blow if Starting is attempted using these points.
Or:
Stephen B Cooper Dc (01-06-2013)
If I were you I'd either jump start the car using leads on the battery - and read the handbook about connecting/disconnecting as it is counter-intuitive - then go for a decent run to charge or put a good quality modern charger on the battery.
I always disconnect the +ve lead when charging after I fried the ECM in a Toyota but it is probably not needed.
The following 2 users liked this post by BobF:
Stephen B Cooper Dc (01-06-2013),
steveinfrance (01-06-2013)
A slightly under performing battery causes all kind of electrical gremlins in these models.
Even if you get the original battery charged and can subsequently start the vehicle, have it checked as it has to be nearing the end of it's useful life.
Always remove negative terminal first, a little slip with wrench hitting a ground point will result in a melted tool. When replacing the battery, positive terminal first followed by the negative terminal.
If this is the original six year old battery, consider a replacement.
Are you in the US or UK? They are widely available anywhere that sells car batteries. Just make sure you get one that has the vent tube included, since it is in the boot.
The Battery is cataloged as a Group 49 and is readily available. I believe that a AGM (Absorbed Glass Mat) version is made, at a substantially higher price ($300) but with a longer service life.
The standard battery should have a Vent Connection to fasten to the Factory Vent Hose. AGM Batteries generally don't need a vent.
In our neck of the woods, these vented batteries are sold by NAPA, Advance Auto Parts, Autozone, Pep Boys, etc. I purchased a Bosch battery at Pep Boys using a $20 coupon I found on their website. Printed it and took it with me to the store. My total cost was about $95. Be sure to check your new battery's build date (month/year), usually contained on a sticker applied to the battery's casing. Get the newest one the store has. And even though the battery is new, check the water level in all six cells to ensure they are full....
Stephen B Cooper Dc (01-08-2013)
