"Check Engine" code P1396
![Question](https://www.jaguarforums.com/forum/images/icons/icon5.gif)
Hello again Folks;
Here I am again... Since having my Chain Tenssioners done, I get a "check engine" light that reads "P1396. The "Check Engine" light was on when I picked her up last week. I just figured it was something that had to be cycled out. When it didn't go out I had the code "pulled" and P1396 was what it read. We reset it and it came back a few days later... Something to do with the valve variable timing solenoid I think. Does anyone think these two things could be related?, is that solenoid anywhere around where they would have dismantled the front of the engine to replace the tenssioners and guides??...
Thanks Again
Fred
Thanks Again
Fred
The VVT solenoids are the electrical connections at the front center of each valve cover. Removing the valve covers requires disconnecting the electrical connections. I just did my tensioners this weekend and also pulled both of the solenoids to make installation easier. Reinstalled, mine worked fine with no codes. Well . . . almost no codes, I did leave the MAFS connector off and got that one.
joesoap
09-10-2015 01:09 AM
OkieTim
09-08-2015 04:48 PM
rachelstr
09-03-2015 12:59 PM
