Check engine light came after disconnecting MAF
Did my sway bar bushings today. Took the top off the air box to get some room to work and in the process disconnected the MAF. When I reconnected the MAF and started her up, the check engine light came on. Never had one before. Any thoughts?
And thanks to everyone who submitted advice on doing the sway bar bushings. Made the job much easier!
Btw, I was surprised to see the old bushings were in fine shape. The new ones seem to have reduced the knock I had developed, but I think new end links are called for.
After taking the car for a longer drive the cel went out on its own. Guess the ecm needed some time to clear itself. The longer drive also showed that I was mistaken when I thought the new bushings lessened the knock. It's there, clear as ever. BUT the car actually handles nicer, which I wasn't expecting! I went with the purple PowerFlex bushings and am very plaesed with them. She just feels firmer and more sure-footed and I know it's not my imagination. And the oem bushes looked to be in good shape, not crushed or torn. The knock however still mystifies me. When it first developed I could have sworn it was in the transmission tunnel. I even pulled the console and radio stack, hoping something was rolling around in there and of course found nothing. End links next and probably shock mounts after them. Certainly can't hurt to renew them.
BrentGardner
28
04-26-2024 03:08 AM
philwarner
12-06-2021 07:13 AM
