Check Engine light on & Restricted Performance warning messgae!
![Exclamation](https://www.jaguarforums.com/forum/images/icons/icon4.gif)
hey all,
Recently my 2002 XKR has been showing the will to switch the engine off whenever I stop at a light or something. The RPM gauge will wiggle around 500 RPM for a second then it'll balance back to normal. I felt it had to do with the spark plugs, but I let go and lived with that.
Yesterday while i was driving it the Check Engine light came on and "Restricted Performance" warning message was displayed for about a minute then disappeared, however, the Check Engine light remained on.
Any thoughts?
thanks
Any thoughts?
thanks
Sam 2002XKR (12-29-2013)
Sam 2002XKR (12-31-2013)
Received 4,323 Likes
Alright guys, I got it scanned at autozone and i got 2 codes: PO172 & P1000
I went thru some relevant threads in the forum and I feel i have to tell you more about my issue: similar to others who had these codes, i'm also getting gas smells when i slam the pedal to the metal. additionally, i noticed the car not showing the will to switch gears (2nd to 3rd) at a couple of occasions.
thanks
thanks
This attachment should explain the codes. As for the Restricted performance it is telling you that it will not allow the car to go over 2500-3000rpm because you have a problem P0172, the P1000 is just a system check it is not part of the problem.
Link http://www.jagrepair.com/images/Auto..._2001_OBD2.pdf
Sam 2002XKR (01-02-2014)
BrentGardner
28
04-26-2024 03:08 AM
Terrance Williams
08-26-2015 11:50 AM
