Check Fuel Filler Cap Light
I'll guess the 'small emissions evap leak'
The gas cap is always first to be suspect, and granted, its the cheapest potential fix, but it'll probably lead you under the car to the vent tube from the cannister close valve to the filler neck, or the valve itself (stuck open due to debris)
report back, so I can check my psychic potential!
Sqeeter91 (04-06-2013)
Thats a large evaporative system leak:
Possible causes:
Fuel cap off
Fuel cap seal defective / missing
EVAP system leak (canister damage, pipework damage)
EVAP Canister purge valve to engine purge pipe: blocked, leaking, disconnected
EVAP Canister purge valve failure (stuck closed)
EVAP Canister close valve failure (stuck open)
Fuel tank leak
Possible causes:
Fuel cap off
Fuel tank leak
Sqeeter91 (04-07-2013)
I changed out my battery a couple of years ago. When I did I didn't put the overflow tube all the way down in the hole to let the overflow drip to the ground. It dripped on my evap canister and the acid burned a hole in it. Could have bought a new one for $350, could have bought a salvaged one for $50 or do what I did. DUCT TAPE!
2001 XK8 Conv.
2001 XK8 Conv.
