Check Rear Lights / Cruise Control Not Available
Got an advisory message on the speedo of our recently acquired 2005 XK8 a couple of days ago - great concern to me because on a freeway at night when it cropped up. Motored on to our hotel, checked all the lights before shutting engine down and found all operating good.
Message was cleared next morning and all systems were good.
Later that day, the message reappeared and cruise shut off when again on the freeway. This time it followed going over a moderately stiff bump.
Drove home about 40 miles sans cruise; at first stop, shut car down and removed key. Reinserted key and the alert was gone when the engine was restarted.
Anyone have experiences with these alerts and have suggestions?
.... and an absolute bitch to remove and replace with a new one. Two people make the job go much faster, especially if the one laying upside-down on the drivers floorboard is less than five feet tall and no more than 80 pounds. Read the threads that pertain to this repair and you'll quickly understand why....
Jim D (06-22-2014)
Reposted
oKay here goes
Complaint: on startup, all is well. Then after a few km of driving, the amber warning dash light comes on with " Cruise not available" and " check rear lights" warning text messages.
Correction: " Checked for stored codes . Found P1571. Brake switch fail, order new switch, Removed and replaced faulty switch, clear codes and road test ok"
PART LJB6420BB. "Switch-brake PE Switch"
plus two hours Jaguar dealer labour charges
Hope this helps
oKay here goes
Hope this helps
A common problem but not so easy fix. The attached link will help you see your way to replacing the switch.
DeaconHull
08-28-2015 05:26 PM
