chirping noise at idle
Supercharger belt noise when the engine is cold is a fairly common annoyance. If it goes away after the engine warms up, that could be what it is.
Cleaning sometimes helps. Safety warning: only do this if you arent fond of your fingers. Start the engine and hold a piece of scotch brite against the belt while its idling. Inside and outside edges are usually the culprit.
Another option is the spray belt treatment. When the scotch brite wouldn't do it I tried CRC Belt Treatment out of desperation. Spritz a little on both sides of the belt while off and then start the car. It made an awful squeezing until the spray burnt off but once that was over, quiet as can be.
Honestly, I wasn't expecting much from the spray but it seems to have kept the squeeling at bay for a few thousand miles so far.
I took the belt off, spun the idler, tensioner and water pump... All okay. WP makes a slight rubbing noise for half a turn each revolution. Washed the front with simple green and water. start up and no chirp. washed off the top of engine and now have restricted perf.. In previous xk8 would get that sometimes when car went in rain.
I'll just blow out all connectors and wait .
baskervillema
10-01-2015 06:43 PM
