Chirping noise from left rear end, frequency related to wheel speed
![Question](https://www.jaguarforums.com/forum/images/icons/icon5.gif)
25mph = chirp....chirp....chirp
60mph = chirpchirpchirpchirp
![Icon Chickendance](https://www.jaguarforums.com/forum/images/smilies/icon_chickendance.gif)
There's something making a chirping noise from the left rear end of the car, probably? from the left rear wheel. Any ideas as to what it could be? I don't have jack stands or a jack, so things I could try to check with the wheels on the ground would be nice.
Could this be related to being sideswiped on the drivers side?
Last edited by GGG; 07-19-2013 at 10:42 AM. Reason: edit typo in thread title so it appears in searches
So reading about chirping on different forums, seems like I should try a few things:
1. Jack up the left rear end and try to wiggle/rotate the tire a little.
2. Take off the tire and check the calipers + brake pads.
3. Switch the rear tires (with help from the spare) and hear what happens.
Although you can remove the wheel to check the tyre / rim for damage and the caliper / pads / back plate for anything sticking, you can't rotate the wheel without both rear wheels off the ground.
Certainly worth starting with taking the wheel off for a thorough inspection.
jagosaurus (07-18-2013)
Pristine97XK8Convertible
09-29-2015 02:43 AM
