cigarette lighter
Old 10-12-2008, 06:27 PM
creativebush's Avatar
Default cigarette lighter
So I went to plug in my iPhone last night to give it a charge while my wife and I went out for a night on the town, low and behold the charger wouldn't light up. Put the cigarette lighter back in, pushed it down and it wouldn't stay down. looks like there's no juice to the cigarette lighter. A minor annoyance but annoying none the less.
Anyone else ever come across this?
Any ideas?
Old 10-12-2008, 09:22 PM
H20boy's Avatar
Received 1,151 Likes on 753 Posts
Default RE: cigarette lighter
Mine originally did not have power w/o the car being turned on (at least in the 'on' position), so during an audio upgrade, I had the lighter put on a constant power wire, so I can charge my phone during the evening when parked.
Old 10-12-2008, 11:00 PM
Hey Matt, thanks for the thought although it happened with the car running backing out of the garage.
Interesting to hear that the plug is only hot while the ignition is on, I always prefer a constant connection myself. My F150 has it and it's great for charging stuff while parked.
Thanks for the info, by chance where do you recall where you pulled that hot wire from? And how much of the center console did you have to dismantle to do it?
Old 10-13-2008, 11:45 AM
dugem260's Avatar
Check your fuses. Mine was "out" when I got the car. I replaced the fuse and it has worked well since that time. Your owner's manual has diagrams showing the layout of the various fuse panels in the car. I believe the one you need to check is accessible with the driver's door open. Good luck!
Doug
Old 10-13-2008, 01:40 PM
wheeble's Avatar
Fuse 14 passenger side fascia box. If it blows immediately, or does not fix it, you have other problems.
Old 10-14-2008, 12:18 AM
Good call guys, I was going to check the fuses... honest!
#14 was burnt out and it didn't burn out immediately upon replacing the 20amp fuse... so far so good.
Thanks for the tips.
This forum ROCKS!
P.S. I also learned while looking in the manual about the fuses that it's a "cigar lighter" not a "cigarette lighter", should have known!
Old 10-14-2008, 04:18 PM
hlgeorge's Avatar
Same happened with mine. It is easy to drop a coin or pen in the lighter receptical and blow the fuse.
Old 10-14-2008, 07:54 PM
ORIGINAL: hlgeorge
I was wondering how the fuse could blow, but now that you put it that way, it sounds entirely plausible.
Old 03-16-2010, 08:36 PM
scarey7's Avatar
I just bought a 2001 XKR and dropped a coin into the cigar lighter within an hour of buying the car. The cigar lighter worked when I first plugged my phone in to charge, but after dropping the coin into the lighter, it seems to have shorted out. However, when I checked the fuse card, there are no blown fuses. Any ideas on what else can be wrong with the cigar lighter? Is there some type of in-line fuse under the center console?
Old 07-23-2012, 09:54 AM
rtucker's Avatar
Hi all,
can someone point me in the direction of where to find the fuse for the cigar lighter, I do not have any instruction manual and cannot find vehicle care handbook for 1997 XK8
Old 07-23-2012, 10:31 AM
SeismicGuy's Avatar
There was also a power-port option that could be installed in the glove compartment (I don't have the part number handy now). As I recall the part was very reasonably priced in the 2005 Jaguar options brochure I downloaded from somewhere but the last time I checked with some of the usual "discount" parts sources the price was pretty ridiculous. Moreover, did not seem all that convenient an accessory since you would need to have the glove compartment opened in order to access the port.
Doug
Old 07-23-2012, 02:05 PM
lilkrissey's Avatar
Originally Posted by rtucker
Hi all,
It is fuse #14 20amp on the passenger side fascia box
jeff_pannier (09-30-2019)
Old 07-22-2014, 09:50 AM
Arland Green's Avatar
You are right- It is the passenger side fascia fuse box. The manual says 20 Amp on circuit 14. Which one is circuit 14? The fascia diagram seems to be the date the plastic cover to the access to the fuse box was made. There is no visible 14 to be seen. There are 3 or 4 yellow 20 Amp fuses there. I'd rather not pull all of them for concern about breaking one- they look delicate.
Old 01-16-2018, 10:38 AM
sean46's Avatar
Do the English call cigarettes, cigars or something? I'd like to know where to get a new "Cig" lighter tho.
Old 01-16-2018, 10:56 AM
Received 6,323 Likes on 5,510 Posts
No, they call them ****. Who would be as uncouth as to smoke a *** in a Jaguar?
Old 01-16-2018, 11:32 AM
DevonDavid's Avatar
If you went to an expensive school (which I didn't) a "***" is rather different !
Norri (01-16-2018)
Old 01-16-2018, 11:39 AM
But not what some may think I'll wager.
Old 01-16-2018, 11:53 AM
Jon89's Avatar
Received 4,369 Likes on 2,857 Posts
Makes me want to listen to Arlo Guthrie's "Alice's Restaurant" (which we do every Thanksgiving Day wherever we are)....
His live performance version of it these days is very different than the original recording....
Old 01-16-2018, 07:22 PM
dsd's Avatar
dsd
dsd is offline
The OEM part is available from the usual sources for about $40. Be warned, It’s a pain to replace— you need to take the center console out and when you reconnect there is very little slack on the wire. Not hard, just annoying.
Quick Reply: cigarette lighter
