It's not a good idea to use jubilee clips or worm-type clamps when connecting a hose to a plastic pipe as they don't allow for dimensional changes due to heat and will eventually cause the plastic pipe connection to fail.
avern1 (03-12-2020),cjd777 (03-12-2020),DavidYau (03-12-2020),Don B (03-12-2020),GGG (03-13-2020),michaelh (03-13-2020),motorcarman (03-12-2020) and 2 others liked this post. (Show less...)
Another reason not to use a Jubilee clip/worm-gear clamp in place of an Oetiker or spring-type constant-tension clamp on any plastic pipe or fitting is that during thermal cycles the flat spot under the screw allows that section of pipe to expand and deform to a greater degree than the rest of the circumference, which promotes cracking/failure at that point of the pipe or fitting.
