Cleaning ECM contacts and grounds
Disconnect the negative battery terminal. Remove the lift out cover at the right rear of the engine compartment. If it's the same as my '97 there is a split cover with torx screws. You only need to remove the 4 screws for the front portion. Use a magnetic bit holder so you don't drop the screws. The cover will come out with a little effort.
The TCU is at the front of the box.Lift it out and remove the connecter. Then remove the connections to the ECU and pull that out. Clean with CRC contact cleaner or equivalent. Clean TCU connections also and reassemble. In front of the ECU box there is a positive cable connection on the outside of the fuse box, and a ground just in front of the fuse box.
There are other ground connections around the car. The JTIS will point them out.
RJ
RJ
RJ
RJ
FS[SouthWest]: Red 2001 XK8 Convertible in Colorado
picard
10-12-2015 11:56 AM
FS[Western US]: FREE- 99 XJR ECM and TCM
XJsc-guy
09-25-2015 11:09 AM
