Cleaning Headliner in Conv.
Does anyone have a good method of cleaning stains on the headliners in our convertibles? I've tried a shampoo at the local power wash places and it didn't even seem to touch them. I was thinking about removing it and putting it the washer, let it air dry and replace.
Has anyone ever removed the headliner?
I have to admit I haven't looked yet to se how it's fastened but I thought I'd ask first.
I had some discoloration in a couple of spots in the rear of the car, near the rear window. I sprayed some "Oxygen Orange All Purpose Degreaser & Spot Remover" that I got at WalMart and it cleaned it right up and did not damage the liner. (I had wiped a small area with it to test it first) It worked on mine, but you may have a more persistent stain. I would try a few gentle methods before removing the entire headliner, if I were you. Good luck.
The orange staining is definitely from the thin foam-backing disintegrating. I have the same problem with my '01. I used rubbing alcohol in a mister and it lightened the stain quite a bit (and spread it a tad). But it will come back as the foam backing continues to disintegrate. If you look at the inside edge where it's sewn you can see the orange backing and if you touch it, it is sticky and crumbly.
I have been investigating replacing the headliner and there seem to be several places on-line that sell replacements (some reasonably priced, some not so much). Either way, it looks like a replacement needs to be professionally installed for the best results.
The only permanent solution to the deteriorating foam is replacement. I did it myself and got good results, but it was a fairly involved job that required a lot of patience, some heavy duty sewing (did it by hand with a sewing awl), a pop-rivet tool (these are inexpensive), drilling out old rivets, crouching for long periods in uncomfortable postions, and some photo documentation of how the old one came apart. Usually the A-pillars and the header above the windshield are also deteriorated, and those should be done at the same time with heavy duty headliner adhesive. (while you are up there in the header, it is a good time to also inspect your latch hoses for deterioration).
Also, I found out that 2001 was a transition year from two piece to one piece headliners. Early builds are two peice, later builds are one piece...you need to identify this before you order a replacement on a 2001.
thanks for the advice guys, I use a product that was called purple power that I got for my local autozone. It got rid of the road grime that bothered me most cause it was up front and very visible. It's a concentrated degreaser so per the recommendation of the sales guy, I cut it at a 5:1 ratio with water (5 parts water) and applied by hand using a sponge.
As for the orangish stains it didn't seem to do much as it's a degreaser. I'll have to try the alc on that.
Did get the ragg topp system and applied that to clean and water proof top, so I hope that helps slow the deterioration.
Removing and replacing the convertible headliner is a serious project. See my post #10 in this thread. If you have never done it before it can take several hours and requires drilling out and replacing pop rivets and a lot of care. In my opinion, it is only worth doing if you are replacing the headliner and take the time to photograph how the old one comes apart. If you do not get your replacement from the dealer, there may be sewing of the plastic bits into the new headliner also involved. If you are not confident in your abilities, have it done professionally and save a lot of grief.
Never thought of alcohol - bottle's usually empty by the time I get to the garage. I found that "Woolite Heavy Traffic" rug and upholstery cleaner works well. It's a big blue spray can, kinda like a super sized paint spray can, that emits a dense foam. All you have to do is spray it on, wait until it dries, and vacuum if the residue fails to fly off by itself. You can massage the foam with your fingers on stubborn stains for better results. I've used it on bird and tree droppings on the canvas roof and it worked well there, too. I've found it to be safe for a variety of fabric types around the house (no stains), but I suggest you test first just in case.
The process I used was to leave the top up and first spot clean the worst areas by hand using isopropyl alcohol on a clean microfiber towel until it looks as clean as the surrounding areas. You may need to change the towel frequently for a new clean one if the accumulated soot is particularly nasty.
I bought a hand steamer vacuum called a Vapamore MR-50 for $150 USD at Amazon and did a modification to the internal circuitry adding a toggle switch so the the steam generator and vacuum operate at the same time. Use a mixture of half IPA and water in the unit reservoir to do the final cleanup over the entire surface of the most forward fabric panels (they tend to get the sootiest) and you're good as new.
-vanremog
-vanremog
I used a product called "Spot Shot" I bought at Sam's Club. I found the best way to clean the liner is to spray the cleaner on a piece of terry cloth towel and wipe the area lightly. Do not spray the cleaner directly on the liner. This cleaner also works great on any carpet stains. When you clean the carpets follow the cans direction.
I think you would be asking for trouble by taking the liner out yourself. If it is that bad, buy a new one and have it installed by a professional. I plan to do both my liner and top at the same time. I almost always have my top open so it might be a long time before I replace it. Good luck with it as you have some good suggestions from the members.
Bill N
03 XKR vert
Bill N
03 XKR vert
