Climate control fan seems to be going out
Started Friday, with a noise coming out of the right most vent, sounded like the blades were hitting something. So I turned off the fan for a couple of moments and then back on and the noise was going. Well today it came back and turning off the fan did not help, but after a few minutes the noise went away.
Where is the fan located and what do I have to do to change the motor?
Car is a 01.
Car is a 01.
That sounds similar to my problem described here:
https://www.jaguarforums.com/forum/x...e-saga-134185/
There's a video on there of the noise that you can compare to.
I've ordered the aux heat pump and I'll be getting it fitted this week, so I don't know if that fixed it for me ( or if we have the same problem, but it sounds like it ).
abonano
25
09-25-2015 10:43 AM
