Code reader options
![Question](https://www.jaguarforums.com/forum/images/icons/icon5.gif)
Being new to the forum and reading many different posts I recognize many of you have code readers to identify faults and interpreting to investigate issues. Are there better code readers, not 'cheap' but inexpensive or is getting a higher price one more important?
Thanks in advance,
Wes
Thanks in advance,
Wes
OBD scanners span the sprecrtum. Everyone has a preference. Below is the thread discussing the attributes. My preference is Icrarsoft for jaguar/land rover.
https://www.jaguarforums.com/forum/g...-%2A%2A-33347/
realjwc (09-04-2019)
On top of getting a proper Jaguar/Land Rover code reader, be sure to also get a cheap ELM327 and a phone app. So cheap, not worth being without. These are great for data logging of basic parameters while you drive, fuel trims, as well as reading (standard) codes and resetting the CEL. An application like Torque Pro lets you build a custom screen with whatever combination of gauges you need, like all the numbers related to the trims: short/long term and bank 1 or 2, along with load and rpm. Speaking in principle, a cheap ELM327 can read everything from any of the 3 data buses, proprietary Jaguar or not. It is jut that the associated app does not have Jaguar support to interpret the data. In other words, as folks discover the encoding of proprietary Jaguar codes over time, it is technically possible to add them to the app.
Best of luck, keep us posted.
Mr Bentwrench (09-07-2019)
I got a Streetwise OBDII WiFi code reader and it works fine with my XE but will not connect to the ECU on my XKR :-(
I've tried various softwares with the same result. I would like to think it is the code reader but as it works fine on my XE i'm not so sure. It is drawing power from the connector in the XKR as i can connect to it with WiFi but just can't access the ECU. So may be a dodgy pin on the connector... any ideas how i can test this theory?
Owen
Owen
I tried this with Torque and no luck but just downloaded another app called OBDclick and forced ISO-9141, connected straight away! Weird how these apps can have such different implementations of what should be a standard.
