Code scanner for 03 XKR
Hey Marsden--does this gizmo have the ability to read % throttle body opening as you push the pedal (with the engine off)? This seems to be one of those issues that frequently need adjustment on these vehicles.
Doug
Doug
Have this on the way from Amazon--will be interesting to compare and (for the sake of future purchasers) see if the extra money was well-spent.
INNOVA 3130 Diagnostic Code Scanner with Live, Record and Playback Data Capability for OBDII Vehicles
![](http://ecx.images-amazon.com/images/I/519XnctF6fL._SL500_AA300_.jpg)
Looks like Marsden has a stuck evap cannister, probably due to corrosion of the vent tube
Been down that road myself just 2 years ago. Good news is it looks like you have a well sealed manifold system, your long term and short term trims look great!
Looks like a good scanner however. One thing about the AE, you can have A LOT of user-selected parameters being shown in real time. It appears this one you may have to switch from screen to screen to compare (like O2 voltages, LTFT / STFT for each bank, etc)/
See? There's nothing like interpretation to make raw data useful.
SeismicGuy, I reviewed the (meager) documentation and couldn't find the answer to your question. Obviously there's TPS data (And ACC Pedal) but that's not what you mean. So I decided to install the PC Link software which came with the scanner but it has hung up on the Microsoft .NET Framework install which infuriates me as I was leery about installing their version of that anyway. Anyone who looks at their Windows Update knows that .NET is all about viruses & intrusions to begin with.
Anyway here's a list of functions from someone else on a Cadillac board. I'm sure you understand more of these abbreviations than I do.
I think there are more than these actually.
When it's not so hot I'll play with the car some more.
(I switched off the A/C in my garage to save energy.)
Fuel sys 1 : CL
Fuel sys 2: CL
Calc load(%): 49,8
ECT : 204F
STFT B1(%) -1,5
LTFT B1(%) 1,5
STFT B2(%) -1,5
LTFT B2(%) 8,5
Eng RPM 1680
Veh Speed mph 19
Spark Adv (deg) 33
IAT 77F
MAF (lb/min) 3,505
TPS(%) 21.1
O2S B1 S2(V) 0,700
STFT B1 S2(%) NA
O2S B2 S2(V) 0.625
STFT B2 S2(%) NA
Command EVAP(%) 1.5
Fuel Level(%) 51.7
EVAP P(inH2O) 0.351
BARO(inHg) 29.5
O2S B1 S1(mA) -0.035
EQ Ratio 11 0.981
O2S B2 S1(mA) 0.054
Eq Ratio 21 1.016
CAT Te 11(F) 1111.4
CAT Te 21(F) 1117.0
ECU Volts 14.017
LOAD Value(%) 44.3
EQ Ratio 0.999
Rel TPS(%) 12.1
Ambient(F) 32
TPS B(%) 22.3
ACC Pedal D(%) 32.9
ACC Pedal E(%) 15.6
Command TAC(%) 16.4
Fuel sys 2: CL
Calc load(%): 49,8
ECT : 204F
STFT B1(%) -1,5
LTFT B1(%) 1,5
STFT B2(%) -1,5
LTFT B2(%) 8,5
Eng RPM 1680
Veh Speed mph 19
Spark Adv (deg) 33
IAT 77F
MAF (lb/min) 3,505
TPS(%) 21.1
O2S B1 S2(V) 0,700
STFT B1 S2(%) NA
O2S B2 S2(V) 0.625
STFT B2 S2(%) NA
Command EVAP(%) 1.5
Fuel Level(%) 51.7
EVAP P(inH2O) 0.351
BARO(inHg) 29.5
EQ Ratio 11 0.981
O2S B2 S1(mA) 0.054
Eq Ratio 21 1.016
CAT Te 11(F) 1111.4
CAT Te 21(F) 1117.0
ECU Volts 14.017
LOAD Value(%) 44.3
EQ Ratio 0.999
Rel TPS(%) 12.1
Ambient(F) 32
TPS B(%) 22.3
ACC Pedal D(%) 32.9
ACC Pedal E(%) 15.6
Command TAC(%) 16.4
I got past the .NET issue so maybe I'll know more in a few.
However have to go to a movie in a few too so it might be later.
