codes
codes
hey forum... been a bit....2001 xk8 was off the road for the winter...just took it out for a long ride (two hour or so straight, back and forth) then engine light came on... checked codes and they were 300,301,303 and one or two i can't remember right now... book says misfiring... how do i fix this problem or is it (may be a low battery causing the codes to appear ..??????????? everything was great up till now with the codes.??? anyway i reset the engine light and i'm going to check it out in a day or so.......any ideas ????????? tony
tony bosco (04-22-2015)
codes
[QUOTE=RJ237;1210250]Put the battery on a charger, then stop at autozone, etc. and have it load tested. Weak battery is the most likely problem.[/QUOTE
.thanks will do had a ctek on the battery all winter cause the windows kept going down when you opened the door . battery is about 5 or 6 years old i guess it just finally had it............anyway will check the load and or buy a new battery................thanks again tony b.
philwarner
25
06-26-2021 05:43 AM
