Coil spring compressor recommendation
Can anyone recommend the correct type of coil spring compressor to use on an XK8.
coil spring compressor | eBay
I just bought these - arrived today - am trying them out tomorrow on my XK8.
I'll let you know if the ends slide in properly between the coils, and if I can get easy access to the screw. This listing is expensive, I purchased mine from an autozone listing for 34.99 on ebay - but it has expired.
25550 Specialty Tool Macpherson Strut Spring Compressor New | eBay
Ok - tested these compressors - the hooks fit fine, but the safety pins will not clear/close over the thickness of the rear spring coils.
Jonscot I tried a similar type on my XKR worked good enough to remove spring, if you are not changing springs you will probably be alright. That style just doesn't cut it compressing new spring, ended up taking to a friends shop and using his Branick wall mounted compressor to install new springs. Good luck be careful.
Apparently they do work, but for the cost of the tool, you can have a shop mechanic do it for you. No risk, no sweat and money well spent IMHO.
That's what I was wondering, these appear to have the single finger on each end.
Jag#4, you say have a shop mechanic do this. How do you get the shock/spring assembly off without compressing it? Does removing the upper A arm first allow room to get the assembly off without compressing the spring? Same for reassembly? Also need to install new upper mounts.
I would much rather pay someone to do the swap if this is possible as I'll probably take the A arm and lower arm to a shop anyway to swap out the ball joints.
As you say for the cost of the spring compressor and the ball joint clamp and adapters for not much more I can have a shop do the work. As far as i have been able to determine no one on Maui has the "free" tool rental program or for that matter a tool rental program at all.
I will be replacing the shock upper mount, shocks, upper and lower ball joints and tie rod ends. So I'll be taking everything off.
I'd performed this a month or so ago, here's a pic of the Harbor Freight compressor, much easier to use than the twin fingers. One note, the support ring (on bottom of spring pic) was a tad wide and gave me problems when I recompressed, I had a friend tack weld some supports on it, the shock bottom plate would slip in between the ring but otherwise this was very effective.
There are other threads/pics of this from other as well.. NOTE there are spring assistors that are in the parts diag but not in some videos.. you should consider replacing these, mine were shot. Good Luck
![Coil spring compressor recommendation-springcompressor.jpg](https://www.jaguarforums.com/forum/attachments/xk8-xkr-x100-17/86241d1480972775t-coil-spring-compressor-recommendation-springcompressor.jpg)
volkris (05-15-2020)
The shop you have pressing in the ball joints should be able to compress the springs to assemble your coils and struts.
Jandreu (05-31-2014)
Yes, you can take the long bolt out of the wishbone and swivel the arm out of your way. The entire strut assembly can easily be pulled out (or put back in) this way. If you are taking the wishbone out for ball joint replacement, even better.
Re watched the Rev Sam video and I see now how it works.
I did find a local place to rent/loan/free the spring compressor and ball joint C clamp tools last night so my give this a try on my own. If it looks dodgie I'll take everything to a shop.
scooternva
20
09-27-2023 11:25 AM
Guy-Pierre Boucher
09-16-2015 05:55 PM
