Compression check
Old 09-18-2012, 11:19 PM
Mendo XK's Avatar
Exclamation Compression check
What is the proper way to check the Cylinder Compression.
Old 09-20-2012, 07:25 AM
Jag13cat's Avatar
Default Compression Check
Based on my information:
After bringing engine to operating temperature:
Disable ignition system from firing
Disable fuel system from delivering fuel
Prop throttle body wide open
Thread compression gauge into each cylinder and crank engine approx.
5-6 revolutions to attain reading - record each cylinder reading
(I mention threaded compression gauge vs the rubber tip hold in gauge for a more accurate reading)
Upon completion, you may encounter a number of fault codes that must be cleared
Mendo XK (09-20-2012)
mrplow58
01-21-2024 05:53 AM
bamforp
09-26-2021 08:04 AM
chatmanx
09-11-2015 07:17 PM
bavareze
09-11-2015 01:49 AM
corysansburn
09-10-2015 06:15 AM
Quick Reply: Compression check
