Condensation in my headlamps
What if you were to remove the paper from an unused tea bag and stick it inside the cover, across the holes, would that let enough air flow?
So ideally the holes in the cover allow air into the headlamp, and others [at the rear?] allow the air out?
If you get onto the Goretex website + find your nearest branch they do Free Samples !!
So you don't need to buy the GoreTex All Purpose Astronaut and Polar Explorer suit and cut holes in it.
Mexk8 (04-25-2012)
Nearest store seems to be 3000 miles away in the neighboring country to the North. If you have a All Purpose Astronaut Suit with the Polar Explorer upgrade option, perhaps you could cut a piece of and send it over?
Its possible that the likelyhood of your doing this is similar to my finding a local store.
Are you missing Marmite aswell?
You must be English to know about Branston and Marmite withdrawal.
Neither can travel on aircraft, of course, all condiments being regarded with deep suspicion since the dreadful Gherkin Bomb incident so I was obliged to smuggle them through the Chunnel packed in the boot of the XKR when I brought it over.
Anyway, assuming that Mexico has a postal service, unlike Nicaragua where I've got a hideout, PM me your address and I'll post you a bit next time we have some in stock. It won't be Scott of the Antarctic variety since if I told you what we use if for you'd have to die but it will serve.
Mexk8 (04-26-2012)
#28
Received 6,323 Likes
I deeply resent these products being branded as Ethnic. Along with Gentleman's Relish and Worcestershire Sauce they were probably on the go long before the US went all independent.
I don't imagine young Washington would have got where he did without the odd Marmite, Branston, Cheddar and watercress sarny.
Mexk8 (04-26-2012)
#30
#32
#33
The Mexican postal service is apparently working fine. In ten years I have never received a single thing. Now you could mail to a friends hotel, La Rana Cansada, Calle 5, entre 5a y 10a, Playa Del Carmen, 77710, Mexico.
I also really miss samosas and anything Indian that could come from a kitchen.
#34
I'll do that when we next get some.
You might find some on packaging
GORE® Protective Vents Frequently Asked Questions
It's different from Gore-Tex and specifically designed for this sort of thing.
You'll find agricultural/pharmaceutical (not the Mexican pharmaceuticals) and other vapour releasing materials will have a small usually round moulding at the top of the packaging with a white film in it.
That's what you want - if you find something let me know. It would actually suit your purpose better than the stuff we use.
Mexk8 (04-27-2012)
#35
#36
Seriously it may be a month or two before I can post you the 'stuff' but I'll let you know when it leaves Blighty.
Mexk8 (04-27-2012)
#37
#38
I had quite an amount of condensation in my HID headlights which was cured by leaving the covers off. Having the same concerns with dirt/rain ingress had the idea of using a breather membrane as used in roofs. I have't put the idea into practice yet but the intention is to cut out most of the plastic cover & to glue the membrane over the hole. I have discussed the idea with a roof membrane manufacturer & providing there isn't too much heat build up they think it may work. Will keep you advised.
Mexk8 (05-01-2012)
rentzoo
11-10-2015 04:56 PM
