Confused about LHD headlight conversion
Hi.
I am in the process of registering my XK8 in France. I am awaiting the CdeC from Jaguar, and am ready to change the headlights from RHD to LHD spec.
I am confused, after reading many posts on here. I dont really know what headlights I have, and how easy it is to change the beam deflectors. Even which deflectors to buy as there seem to be at least 2 types.
My car is a 1998 coupe. Can anyone tell me how to identify the headlights. Then, I am sure I have seen guides on how to remove the deflector plate, I will be able to follow the relevant one.
Paul
Paul
Hi.
The job is amazingly easy, if you have standard early headlights.
I took off the front wheels to make access easier. Then, in the front of the plastic liner, you will find a removable cover, giving access to the rear of the headlights. Unplug the dipped beam bulb, but leave in situ. Then, you will see 3 small screws, 7mm heads I think. Remove these, and the rear silver/chrome bowl can be fiddled out, and then you can remove the beam deflector plate. This is the part you need to replace or modify. You will see a step on the top edge. If you are handy, and have some good tinsnips, you can cut the step the opposite way. Hard to describe, but im sure youll understand when you see it. The biggest problem with doing this is that you have to manipulate the plate to set the beam at the same height as the lights arent adjustable. I drew the beam height on my barn door, and adjusted to this height. It took several attempts, after making sure that I had measured the height of the top of the wheelarch so that the car sat at the correct height without the wheel on.
A lot easier would be to buy the correct metal plates, which you can find on fleabay, or jaguar specialists for around £60.
If I had bought the plates, I could have done both in a lot less than an hour. It took me under 2 hours having to manipulate the plates, but a good saving as far as im concerned.
Good luck with the lights, and in Spain.
Paul
Paul
GGG (01-28-2014)
@Ukdude,
As far as I know all 4.2 cars have hid lights, and these plates are different then for the halogen ones creuse101 describes.
Its a long time ago I played with it, but iirc you can just flip the plates within the headlight (so the high side of the plate should switch sides), that should do the trick.
Hi.
![](https://cimg9.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/1500x2000/img_20150528_202138_eea39a7d32d1a9b3aeaeffd37ce0829a2d6b1a9f.jpg)
View of the back of the headlight through the access panel in the liner.
![](https://cimg3.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/1500x2000/img_20150528_195902_0c93e92edf4e70699650afaa15a5465684c026b0.jpg)
Back of the bulb holder/reflector with the three 7mm bolts that need to come out.
![](https://cimg8.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/1500x2000/img_20150528_201004_b8d9004257af68ab143b68091f03272c8d4d5e07.jpg)
The RHD deflector. This is held in place by the reflector bolts.
This thread talks mainly about standard (halogen) headlights. Have a look here for the HID conversion:https://www.jaguarforums.com/forum/x...s-67023/page5/ which sounds like the thread you are looking for.
Hello ,Somewhere on this endless discussion on RHD to LHD headlight conversion I am sure someone said if you just swapped the whole tin flap assembly left to right and vice versa it worked .Can't find the original piece is it too good to be true or did I dream it ?
baskervillema
10-01-2015 06:43 PM
zigzewel
09-29-2015 12:42 PM
