Confused with these part numbers
Hi, I noticed that there are two versions of the following parts: tie-rod ends and front lower control arm ball-joint, for an ‘04 Jaguar XKR.
Can anyone confirm that these part #s fit my car:
MNC1350AA - Ball joint
JLM9660 - Tie Rod
Which of these is the correct steering rack mounting bush?
MJB3953BA
MJB3953AA
MJB3953AC
Are the the ones sold by Welsh OE or aftermarket?They seem to be rather inexpensive.
JLM9660 - Tie Rod
MJB3953BA
MJB3953AA
MJB3953AC
Received 4,319 Likes
If you check SNG Barratt's site - JLM 9660 has been superseded but it will fit your car https://www.sngbarratt.com/us/#!/Eng...6-424bbf37fd7b
MNC1350AA doesn't list applicable models
MJB3953AA/BA both show they cover from VIN 024687 through the 2002 MY and MJB3953AC comes up no match
Here is the link toe the SNG catalog for 2002-2006 MY https://www.sngbarratt.com/us/#!/Eng.../47/all/1/10/1
Steering rack bushings are MXD3953AA/BA for driver/passenger sides https://www.sngbarratt.com/us/#!/Eng...20AND%20PINION
I found my lower ball joints at Christophers Foreign Car Parts, part #350596986962, paid $97.90 for them both several years ago. Can't remember if these were Lemforders, but they were made in England.
3/16 plate, 2 pcs angle iron, 2in tubing,20 ton press, balljoints are in!!!
Had to make my own jig so to press them in, but was well worth it! Hope this helps.
Cheers, BK
![](https://cimg4.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/600x338/picture_php_pictureid_28550_cf9bf3604805584a46528d665bc5a5e8f35b63b0.jpg)
Cheers, BK
The following 3 users liked this post by Hdpartsman00XKR:
The lower balljoint is part number MNC1350AA. See link below, the # vversion is made by Lemforder (Original)
https://www.sngbarratt.com/us/#!/Eng...#resultsAnchor
giandanielxk8 (02-12-2019)
Thank you very much!
XKE66andXK8
10-14-2011 11:13 PM
