CONVERTABLE TOP HELP
I JUST BOUGHT A 2003 JAGUAR XKR. AND LAST WEEK MY AIR HOSE BUSTED ON MY TOP. THEY CHARGED ME $1250 TO FIX. NOW THEY SAYING MY AIR PUMP GONE BAD.. AND IT COST $2000 FOR THE PUMP AND $500 TO FIX IT. THEDEALER CHARGE TO MUCH.IT WONT LET MY LATCH ATTACH AND IT WONT LET MY TWO BACK WINDOWS RISE UP.. I TRIED MANUALLY LATCHIKN IT BUT THE LAST OWNER STRIPPED THE HOLE... I NEED HELP..LOL.. BUT I DO... ANY ONE WITH SUGGESTION
I've lost three long posts trying to address your issue. Kicks me completely out of the site.
Anyway, hopefully you have found the pump by now. By-pass valve is the brass 'T' handle on the trunk side of the pump body. Closed is clockwise. You want it closed. Open is for manually raising/lowering top. Check fluid level also. Should be about an inch from the top. It is marked but difficult to see.
If you really have a pump problem, which I do not believe you do, I have one I will give you for the shipping charges. It has a bad solenoid due to a previous owner tearing off the electrical connector and will require your reservoir as the used one I bought leaked.
Way too low!
The two horizontal lines on the side of the reservoir are the MAX/MIN fill lines.
If you paid someone to fix the top latch they should have left the reservoir properly filled. Otherwise, Pentosen CHF 11S hydraulic fluid available at NAPA for $17 a liter. Fill with a turkey baster from the Dollar Store and $0.50 of plastic tubing from a hardware store. Requires a small diameter tubing.
Spelling
Spelling
Hi Gus. Thanks for your pics on the top hose replacement. As you can see this is a common problem and anyone wanting to replace the complete hose should view your photos before beginning the project. BTW, I am beginning to think total replacement is a much better fix. This thread is case in point. He notes the leak is in the general area of the splice. I would not be surprised if the splice itself was the problem Hopefully he only needs to tighten the couplings.
Did you resolve your Restricted Performance warning text?
Gordo
Gordo
FS[Western US]: Jaguar xk accessories for sale
jfitzoz
09-07-2015 04:28 AM
