Convertible Cover Tubes and Plugs
I just noticed I am missing all 6 plugs and 2 of the 3 plastic tubes that hold my cover under the boot lid.
Is there another source for these??
Jaguar Part#s
CBC7363 Plug
HJA7845DA Plastic Tube
I am sure I can find a plastic tube the same size....but I've never seen the plugs before.
Rich
Jaguar Part#s
CBC7363 Plug
Rich
Received 4,285 Likes
Rich - check out SNG Barratt - forum sponsor as they show both on their website
SNG Barratt - The Ultimate Jaguar Parts Specialist
regards,
steve
regards,
steve
The following 3 users liked this post by sklimii:
Received 6,315 Likes
This :
and five minutes with a small hacksaw will yield 10 plugs, as many tubes as you want, and a fair amount of writing in the meantime !!
You stuff them in the ends of the tubes. Supposed to keep the tubes from falling out. But they fall out of the tubes. Then the tubes fall out of the cover. Then you have to buy some more.
Jack
Chuck Schexnayder (12-09-2014)
You can easily accomplish the same goal with a quarter-inch or three-eighths-inch wooden dowel. Cut it into sufficient lengths, dip the three segments into a can of waterproofing treatment such as Minwax Spar Polyurethane, let them dry, insert them into the loops using a bit of epoxy to hold them in place, allow the epoxy to cure, and you're good to go. If you already have the dowel, the polyurethane, and the epoxy sitting on your garage shelves, your fix is essentially free....
FS[Western US]: XJS Lock Set with Keys- Doors, trunk, glove, gas, and ignition
XJsc-guy
11-23-2015 01:56 PM
rachelstr
09-03-2015 12:59 PM
