Convertible Discoloration??
I recently used 303 cleaner and guard to clean and treat my black convertible top. Cleaned the whole top with no issue.
When it was time to treat/seal the top, at first, I accidentally bought a one ounce bottle of 303 and then used the whole once on just less than half the convertible top.
Then I ordered a large spray bottle and did the remaining areas of my top with less saturation.
NOW, the areas I treated with the one-ounce bottle have a slightly brownish discoloration right along the lines where I sprayed the treatment.
Will this wash out eventually?? This car has gone 14 years without a single blemish, I'm going to be really pissed if the top is now discolored!
Thank you as always!
I've had excellent results with the Renovo products. I would order both the cleaner and the Reviver. The cleaner to remove any pre-existing waterproofing and the Reviver to seal and color.
Convertible Car Care by Renovo - Soft Top Cleaning Products
Thank you all for your replies. I spent some time cleaning the seemingly discolored area, using the 303 multi-surface cleaner. It looks like the issue has improved markedly.
I assume the problem was the fact that I initially purchased a 1 oz. container, which does not spray very effectively. I therefore ended up massively saturating part of the convertible fabric.
Looks like a light coat is better to start off.
I think this issue is resolved, so readers shouldn't take this as a criticism of the 303 product line! The cleaner and guard have been great otherwise.
StuG (03-14-2016)
IndelXK8
03-27-2016 08:33 PM
