Convertible fuel pump replacement thru shelf cutout ??
Howdy Folks:
Having read the Fuel pump replacement thru the subwoofer!! thread I am curious as to or not to try to cut an access hole thru the package shelf as I have needed to replace my pump(s) for sometime. I am leaning toward cutting the hole and using a patch panel.
Both positive and negative comments appreciated.
Thanks in advance.
Thanks in advance.
Dr. D (07-19-2014)
I cut the hole for fuel pump replacement using the instructions from this thread
https://www.jaguarforums.com/forum/x...access-118362/
It worked out great and it saved me from having to remove the tank.
Dr. D (07-19-2014)
BrentGardner
28
04-26-2024 03:08 AM
