Convertible hood seal replacement
Hey all,
Awaiting delivery of a full set of roof seals to replace the ripped and torn originals. I have looked at how to remove them but it doesn't seem too obvious nor have I found any instructions on forum/online. Does anyone have any info on how to remove/replace them please.
Thanks in advance,
Thanks in advance,
Hi.
I have only done the front ones. I think the middle ones just pull out of their rails.
To do the most aft, I think you have to do some more dismanteling and take out a screw holding them.
It is essential to keep the seals well lubricated, especially if you use your car in the winter.
Adjusting the window correct will keep out noise. There should be no gap between the door window and the aft quarter light.
Davebc (05-05-2014)
I have seen manufacturers, (BMW, e.g.), recommend the use of a thin coating of silicone grease on door and window seals. If that is not done, the window seal can stick to the glass and get torn or get pulled apart when the window is opened. Rubber seals can dry out quickly in the desert.
Thanks again.
Charlie
Thanks again.
Charlie
BrentGardner
28
04-26-2024 03:08 AM
rusty37
06-07-2016 04:43 PM
