Convertible Latch Leaking
Received 4,317 Likes
<p>Most likely the hoses have deteriorated and will need replaced. It can be done DIY or farmed out to local indie. If the latch hoses are bad, check the RAM hoses as well. If the outer black layer is flaking off the hoses - recommend replacing all at once. </p><p>A complete set of hoses is around $600. I used Cabriolet Hydraulics when I replaced mine, Top Hydraulics is also a recommended vendor.</p><p>Take a look at Gus's website (link below) for procedures on replacing</p><p>JagRepair.com - Jaguar Repair Information Resource</p><p>If your lucky, you may have another member in your area that has experienced this phenomenon and would be willing to assist for a cold beverage or two.</p><p>regards,</p><p>Steve</p>
Don't be intimidated if you decide to swap the hoses and cylinders yourself. Lots of pieces but it's fairly straightforward and there are lots of good photos on the forum. I did mine in the spring and it all went smoothly. I also put in Gus's relief valve for some extra piece of mind.
Good Luck!
Randy
Good Luck!
Randy
99xk8guy
06-05-2023 06:28 AM
rachelstr
09-03-2015 12:59 PM
